disabling the DRL's
<blockquote data-quote="WestCoastDan" data-source="post: 459601" data-attributes="member: 23120"><p>Yes, you should be able to access & edit the DRL settings using JSCAN & a compatible OBDII scanner/reader.</p><p>A license for your VIN # is also required.</p><p></p><p>No, there are no good instructions or decent software roadmap, but it is mostly intuitive and you should be fine.</p></blockquote><p></p>
[QUOTE="WestCoastDan, post: 459601, member: 23120"] Yes, you should be able to access & edit the DRL settings using JSCAN & a compatible OBDII scanner/reader. A license for your VIN # is also required. No, there are no good instructions or decent software roadmap, but it is mostly intuitive and you should be fine. [/QUOTE]
disabling the DRL's
