Dead Jeep
<blockquote data-quote="Duster" data-source="post: 454274" data-attributes="member: 20812"><p>Is there a way you have been able to start it? Your wording suggests that you can. However, assuming it's just dead, if there are no dash lights, no clicking when you turn the key, no noise, then it sounds like there is a broken line between your battery and the rest of the system. Since the wiring harness was replaced, that looks like a place to start. There's also a possibility that there might be a grounding problem.</p></blockquote><p></p>
[QUOTE="Duster, post: 454274, member: 20812"] Is there a way you have been able to start it? Your wording suggests that you can. However, assuming it's just dead, if there are no dash lights, no clicking when you turn the key, no noise, then it sounds like there is a broken line between your battery and the rest of the system. Since the wiring harness was replaced, that looks like a place to start. There's also a possibility that there might be a grounding problem. [/QUOTE]
Dead Jeep
