So I was working on my jeep all day to flush the cooling system. Pulled the radiator petcock and took off the radiator cap. (No problems)
Once all the coolant was drained I removed the top radiator hose and replaced the thermostat and thermostat housing, and put the radiator hose back on. (Still No problems)
Then I put the petcock back into the radiator and filled the cooling system to full with distilled water and some cooling system cleaner. (No problems)
I then disconnected the battery completely and replaced the Coolant Sensor (This is where the problem started)
Once the new coolant sensor was installed, I opened the Radiator cap to make sure the radiator was still full.
Once the cap was off all I heard was a flood of fluids from beneath my jeep.
I look under my jeep and it was leaking water from 4 different places.
What would be the cause/solution for this problem? [This is on a wrangler unlimited '08 if that makes a difference
Nothing was leaking from anywhere with or without the radiator cap on all day, until the coolant sensor was replaced
