Cooling system changes
shebuski.j
DeWitt Michigan
I am replacing the radiator on my 2008 JK. After removing the leaking current leaking radiator, I noted a significant amount of debris between the condenser and the radiator and in the plastic tray below them. Would there be any reason to NOT remove this tray? After reviewing several videos on YouTube, it appears some of these pans have been removed. Thanks for your input.
It's a protective guard that keeps crud and small debris from getting up in there. If you don't go off road much, than you'll be fine taking it off. But if you do, leave it, it's saved me several times when I go through the brush.
