Car wont charge
Taylor
Palm Bay, FL
2010 Jeep Wrangler Sahara: New battery, new alternator and car wouldn't charge. Put an external VR and idles at 14V but revs at 17V so still not driveable. Any suggestions please.
If you put a external regulator on the case of the regulator has to be grounded good, I always like to run a ground wire from a case screw to the alternator case. If it's not grounded good it will overcharge.
The regulator is grounded to the frame, I will try changing the ground.
Check your grounds to the block and the frame.
I have this regulator. The alternator is not attached to the ecm any longer
Do you have the Modified Driver or isn't it needed? Also I think it 's the one with a adjustment on the back to adjust your charging volts, is it?
