Can I run 35s on stock Rubicon Hard Rock wheels?
Burbano
New England
Hello,
I have a 2018 JKU rubicon recon with a 2 in suspension lift and stock wheels and tires. I want to upgrade to 35s (Goodyear wrangler duratrec) for a tire size but will this fit on my stock rubicon wheels with the 2 in lift or will I need to get new wheels if so what size?
While your waiting for someone to answer your question you might read these 2 Threads they are about your same question.
If you want to keep the factory Recon wheels, you need to get the Quadratec versions to run anything 33" and larger. They are identical, but they have the appropriate backspacing (5.2") to run a 35" tire.
This is them:
In addition, to properly run a 35" tire, you need a 4" lift.
