Broken valve spring engine swap?
vajeeperman
Springfield, Virginia
I bought a 2012 sahara last year. I've had it for 4 months and a valve spring broke and valve bent. I found a company that does reman engines and am thinking of doing a swap. Anyone here know a good shop in Northern Virginia capable of doing a good job?
I've already sunk 7k into this bad boy and don't want to let it go.
Is there some reason you're talking about replacing the entire engine? From your post, all you need to do is pull one head to replace a valve and spring.
Reactions: tJKrider
Write your reply...
