D DanWirth New Member Joined Jul 2, 2021 Messages 1 Location Milwaukee,WI Jul 2, 2021 #1 My rear transfer case is grinding terribly. Jeep won't even run, unless I'm in 4 wheel drive. Need help bad!
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 5,382 Location Huntington In Jul 2, 2021 #2 Your transfer case or your rear axle? Doesn't really matter they are probably ruined if you have to put the Jeep in 4x4 just to make it move. If it's your rear axle have you checked to see if it could be your brakes in the rear froze up and the pads are down to the metal? Reactions: Duster and mrjp
mrjp JK Enthusiast Supporting Member Ride of the Month Winner Joined Sep 1, 2020 Messages 829 Location Northern Nevada Jul 2, 2021 #3 When you put it in gear does the rear drive shaft turn? If so it's most likely something to do with the rear end.
MacGuyver JK Addict Supporting Member Joined May 13, 2020 Messages 1,006 Location Wisconsin Jul 2, 2021 #4 Rear transfer case? You mean the rear differential? Give us as much info as you can so we can help as best we can. Reactions: Duster and mrjp
