Broken ignition actuator pin
Newjeepguy
South Carolina
So I recently broke the pin while trying to put a new ignition switch on my 2009 jeep wrangler x. I managed to get the steering column ignition lock housing (chr# 05057296AJ) off the steering column. How do I open it to try and change the pin ?
Reactions: isortiz
Did you figure this out? I just broke mine as well and can’t seem to find a replacement part or reference anywhere.
Reactions: isortiz
Hello, Same issue did you have to buy a new steering column ignition lock housing? Or did you open and changed the pin?
Did you ever figure out how to open it ? I have the same issue
