Broken ground stud
sammykitch
South Carolina
Today while installing a dead pedal
The forward of the 2 grounding posts snapped.
Are these replaceable?
Thanks in advance for any help This is a stock photo but its the front of those 2 studs with the yellow insulation.
I had enough left to remove broken piece and tighten grounds but not enough for dead pedal.
You should be able to replace those, yes.
You can try to find a replacement stud from a Jeep dealership or an online parts retailer. Just make sure to get the correct part number that matches your vehicle's year and model.
If you're in a pinch and can't source a new stud right away, some Jeep owners have successfully used a small bolt and nut to create a temporary fix. Just ensure it’s properly insulated and has a good connection to avoid any electrical issues.
