Best setup for road and trail
<blockquote data-quote="Anybodyhome" data-source="post: 463638" data-attributes="member: 19161"><p>2014 JKU Sahara. 2.5" lift with 35x12.5; 3.73 rear end. Adding an 80lb front steel bumper dropped the lift closer to 2", but still plenty of room for the 35s. Added Pedal Commander for a better throttle response and it does very well on moderate trails and will still run 70+ on the interstate at less than 2600 rpm.</p><p></p><p>I like the combination. I thought about going to a 4.10 rear end, but I've not had any cause to after 8 years of driving it.</p></blockquote><p></p>
[QUOTE="Anybodyhome, post: 463638, member: 19161"] 2014 JKU Sahara. 2.5" lift with 35x12.5; 3.73 rear end. Adding an 80lb front steel bumper dropped the lift closer to 2", but still plenty of room for the 35s. Added Pedal Commander for a better throttle response and it does very well on moderate trails and will still run 70+ on the interstate at less than 2600 rpm. I like the combination. I thought about going to a 4.10 rear end, but I've not had any cause to after 8 years of driving it. [/QUOTE]
