So my wife's JK has had steering issues since we bought it almost 2 years ago. Yesterday I hit a bump getting on the freeway and had the worst deathwobble in it so far (thought we had it cured).
Set up: 2013 JKUR on 2.5" metalcloak lift. (installed 2 months ago)
Within the last year I've replaced:
Teraflex HD ball joints October 2019
Yeti track bar November 2019
Yeti top mount drag link November 2019
Yeti tie rod November 2019
Metalcloak control arms September 2020
Wheel hub assembly today
Today I checked to make sure track bar on frame side isn't wallowed out, checked ball joints, and replaced drivers side wheel hub assembly because I thought maybe it made a sound when trying to wobble the tire top to bottom.
I had the tires balanced in May 2020 and the tech said they were very out of balance. When I look at the wheels there's a TON of weights on them.
I did a driveway alignment when I put the control arms on, but I'll be taking it in for an alignment check as soon as I can. Last time the alignment came back within spec and had deathwobble so I don't think that's the problem but worth a free check.
My 2 thoughts are:
1. The death wobble seems to come on when hitting a pothole while turning, rarely if ever happens when going straight down the road. Is it possible the steering gearbox could be the cause? It's one of the only things left I haven't replaced.
2. Is it possible the wheels are out of balance again, and could that be a cause? I've read wheel balance is an unlikely cause, but I'm running out of things to replace/look for.
My 2 thoughts are:
