Bad PCM causing misfire on 2/5? Damaged coil
anarky321
Charleston SC
so i thought this would be an easy fix - ignition coil has a cracked hole at 2/5 causing a double misfire
however replacing the coil the issue was not fixed - to be thorough i replaced the plug and wire as well on both cylinders
is my PCM damaged? can it be repaired?
2011 3.8 sahara unlimited
