Axle Breather Tubes
Stormydog
Illinois
I just did a leveling kit and my breather tube to the axel is a little tight. Should I get some extra tubing and a connector to make it longer? What do the big lifts do? 2017 Jeep JKU Sport.
If you're actually be underwater, you will need longer vents. What I did was run the hose into the engine bay. Grab a filter like you put in your valve covers. Plug the hose into that and mount it high on the firewall. If that goes underwater, you're likely to have worse worries than your gears.
If memory serves me right, I think I replaced my breather hoses with 3/8" rubber fuel line. I ran the front into the engine bay and mounted on the firewall. The rear I ran up and behind the taillight.
