AX15 4.31:1 Low First Gear Conversion Q&A
NovakConversions
Vendor
Logan, Utah
Lot's of questions about this in another forum so I wanted to start this Q&A thread.
Here is the conversion; https://www.novak-adapt.com/catalog/transmission/transmission-parts/ax15-low-first-gear.html
YES! It is retrofittable to existing transmissions. Note: very early AX15's had a nut on the shaft where there is now a snap ring. So the early version will need an additional snap ring along with this kit.
I personally would recommend at a minimum doing a bearing set while you do this conversion, just for good insurance.
Please post any questions you have!
