Other Jeep Models
Other Jeeps
"A Jeep Rescue" Home for troubled Jeeps is at it again with another engine swap!
<blockquote data-quote="RangerRick" data-source="post: 448347" data-attributes="member: 18868"><p>Can't really use any transmission that came stock in a Jeep because they are all too weak or if from an early CJ and strong enough, don't have any O.D. capability which is a real problem for any street driven Jeep.</p><p></p><p>I will keep you all up to date.</p><p></p><p>BTW, I am putting together the build on the sister forum <a href="https://wrangleryjforum.net" target="_blank">https://wrangleryjforum.net</a> if you care to check it out. Will be dropping more photos on it in the future when I get the time to edit.</p><p></p><p>RR</p></blockquote><p></p>
[QUOTE="RangerRick, post: 448347, member: 18868"] Can't really use any transmission that came stock in a Jeep because they are all too weak or if from an early CJ and strong enough, don't have any O.D. capability which is a real problem for any street driven Jeep. I will keep you all up to date. BTW, I am putting together the build on the sister forum [URL]https://wrangleryjforum.net[/URL] if you care to check it out. Will be dropping more photos on it in the future when I get the time to edit. RR [/QUOTE]
Other Jeep Models
Other Jeeps
