B Bag New Member Joined Feb 3, 2024 Messages 4 Location Huntingdon, Pa. Feb 3, 2024 #1 It's my first Jeep. I was changing the oil and noticed 3 holes just behind the drain plug. One has a rubber "plug" in it and the other 2 do not. Is this normal? Sorry if this has been asked before.
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 5,123 Location Huntington In Feb 3, 2024 #2 Are you talking about the bottom of the bellhousing?
B Bag New Member Joined Feb 3, 2024 Messages 4 Location Huntingdon, Pa. Feb 3, 2024 #3 BLACKJKU said: Are you talking about the bottom of the bellhousing? Click to expand... Yes sir.
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 5,123 Location Huntington In Feb 3, 2024 #4 It's normal, if your rear oil seal or front trans seal leaks the oil comes out there. Reactions: BigAL07
B Bag New Member Joined Feb 3, 2024 Messages 4 Location Huntingdon, Pa. Feb 3, 2024 #5 BLACKJKU said: It's normal, if your rear oil seal or front trans seal leaks the oil comes out there. Click to expand... Thanks. I thought maybe I was missing 2 plugs.
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 5,123 Location Huntington In Feb 3, 2024 #6 Bag said: Thanks. I thought maybe I was missing 2 plugs. Click to expand... I'm not sure if they are all supposed to be plugged or not, I supposed if you Offroad and drove through water you'd want them plugged. Reactions: BigAL07
