F F250 New Member Joined Apr 29, 2020 Messages 5 Location Texas May 8, 2021 #1 2017 JKU - previous owner added grabbars above rear doors. I’m needing to remove them but I don’t have the original bolts to go back in soundbar. Anyone know what size they are? Just the 2 on each side. thanks
Lxxtsy JK Enthusiast Joined Oct 16, 2019 Messages 352 Location Somewhere on Earth May 8, 2021 #2 can't you reuse the bolts holding the grabbers back into the sound bar? Reactions: F250
F F250 New Member Joined Apr 29, 2020 Messages 5 Location Texas May 8, 2021 #3 They’re too long and I need a washer.
Lxxtsy JK Enthusiast Joined Oct 16, 2019 Messages 352 Location Somewhere on Earth May 8, 2021 #4 you either can add more washers to make it fit or take another sound bar bolt out and check local hardware store.
F F250 New Member Joined Apr 29, 2020 Messages 5 Location Texas May 8, 2021 #5 That was going to be my next step, just checking to see if someone knew the size. Thanks
Lxxtsy JK Enthusiast Joined Oct 16, 2019 Messages 352 Location Somewhere on Earth May 8, 2021 #6 Gotcha and good luck.
