2016 Sahara randomly dies while driving
<blockquote data-quote="Cooperstock" data-source="post: 459607" data-attributes="member: 25163"><p>Update: Changed the charcoal canister valve (appears to have fixed the 'gascap' warning). The next time the engine shut off it threw a P0335 Crank shaft sensor engine light (hasn't done that before). I changed the sensor, so now we will see if it stays running. The guy at Orilies said his jeep did the same thing and after changing the sensor it hasn't died sense.</p></blockquote><p></p>
[QUOTE="Cooperstock, post: 459607, member: 25163"] Update: Changed the charcoal canister valve (appears to have fixed the 'gascap' warning). The next time the engine shut off it threw a P0335 Crank shaft sensor engine light (hasn't done that before). I changed the sensor, so now we will see if it stays running. The guy at Orilies said his jeep did the same thing and after changing the sensor it hasn't died sense. [/QUOTE]
