2013 Jeep JK Wandering While Driving
<blockquote data-quote="Duster" data-source="post: 464073" data-attributes="member: 20812"><p>Two questions. First, what do you mean by "skating." Also, you play in your steering. It's unclear if you are handing about a total four inches of slop, two left and two right, or just a total of two inches. Four inches of total play would definitely cause some problems holding a line or correcting after turning. Second, did the work you had done correct whatever play there was in the steering? If it didn't, I think that is your problem. You might want to look at play in the Pitman arm and steering box.</p></blockquote><p></p>
[QUOTE="Duster, post: 464073, member: 20812"] Two questions. First, what do you mean by "skating." Also, you play in your steering. It's unclear if you are handing about a total four inches of slop, two left and two right, or just a total of two inches. Four inches of total play would definitely cause some problems holding a line or correcting after turning. Second, did the work you had done correct whatever play there was in the steering? If it didn't, I think that is your problem. You might want to look at play in the Pitman arm and steering box. [/QUOTE]
