2011 JKUR automatic transmission cooler leak: is there a replacement plug?
TJM III
Outside Atlanta, GA
Hi all, was changing the oil and noticed a lot of dirt/oil (from a prior gasket leak) on the auto trans cooler lines. Wiped them off, but think I pulled out a real small plug from the crimp connection on one of them.(See picture) Now when I run for a while ATF seeps out the hold in the pic on the top hose line. The other connectors seem to have very small plugs in them. I must have pulled it out, but can't find it.
Trying to avoid replacing the lines or cutting and using hose and clamps like I've seen in other posts. I've searched the forum and other places and cannot find any issue similar to this. Does anyone know if there are replacement plugs? Or I saw some small silicon high temp plugs on amazon- wondering if those would work. Or any other solution rather than replacing?
Not supposed to be a plug there, it's just the way that crimp piece is made that holds the hose to the line.
