I have replaced all tie rod ends, all 4 front ball joints, power steering pump, rear outer bearings, front hubs and I had all the u joints replaced on the drive shafts and the front axles.
I have a 6" rough country lift (short arm) installed on my Jeep I run 35 12.50 tires
Anyhow so every time I get going and start shifting gears its like my jeep bucks sideways a bit in between shifting gears, also if I let off the gas and kind of just coast its hard to keep it going straight. Makes me look like a drunk driver. where should I start? all bolts are tight on all upper and lower arms on my suspension. both front and back sway bars are attached with connects and the problem still persists.
