09 JK Transmission Issue
Asulli09
Mobile, Alabama
*Please Help*
09 JK with 157,000 miles very clean and well kept. Had the transmission rebuilt 8 months ago and just got two codes P0841 and P0846 and Jeep goes into limp mode. Took it back to transmission shop (still under warranty) they stated it was a pcm issue not a transmission issue. So I bought a new pcm from wranglerfix, installed it and with in 2 minutes same code and back into limp mode. I can turn the code off and it will run fine for a few minutes then same codes and back into limp mode. Had it towed back to the transmission shop where they stated they would replace electronics (valve body and sensors) in tranmission. Any idea if electronics are good where do I go next. It's been a month and I still don't even know what the problem is. I have not found one thing on the internet about anyone getting these two codes. Thank you in advance.
Here are what the Codes mean and the repair for them. Most of the causes are for internal pressure switches/wiring problems.
Write your reply...
