Hello friends, first of all, I want to congratulate you on the incredible site you have here. I hope you can point me in the right direction. This is my first post on the site, so I apologize in advance if I break any rules. Please let me know and I'll try to do better.
09 Jeep Wrangler 3.8
federal emissions
The previous technician was chasing a P0031 code, managing to isolate the problem to a bad PCM. We ordered one from All Computer Resources, which is the company we've worked with, replaced the O2 sensors with NTK sensors, and now we're getting P0037, P0057, and P0031 and rough idle.
We've already confirmed good ground at G104 and G103, added new grounds between the chassis/block and battery block, and have good ground at the O2 sensor connectors. Backprobing at PCM suggests the PCM isn't delivering the same voltage at B1S1, B1S2, and B2S2. We returned the PCM to the seller, and $50 later he said there was nothing wrong with it and sent it back.
I have repeated the same checks with the same results. I'd bet on a bad PCM, but maybe there's something I'm overlooking.
I should mention that the original PCM was damaged when they tried to inspect it; the car wouldn't start after we put it back. I have nothing to compare it to.
So, I should have almost the same value on the heater control lines, right?
What should that value be?
could be a bad TIPM?
I've looked for information on this but nothing specific. I've found some good advice within this same forum, but I'm still lost.
Thanks for you replies guys!
federal emissions
