Hello everyone,
I just joined this forum in hope that someone can help.
My jeep has had a problem for a couple of months now. When I hit a bump, doesn't seem to matter severity or speed, my chime goes off, the RPM gauge drops and returns to normal one or several lights flash on and often some will stay on. The oil, check engine, airbag and ESP/BAS lights specifically. This happens at highway speeds or crawling through a parking lot, pot hole patches, speed bumps, cracks in the road or the gaps left in the pavement of a parking lot. It doesn't happen on every bump however.
I'm at a loss for where to go or what to check.
Sometimes the check engine light stays on and I can pull DTC codes, U0002, U0100, U0101, C107D, U0141, U0146. Other times when checking codes I get nothing on the DTC but using the ABS code function I'm able to get U0002, U0101, U0141, U0146, U0100, U0429, C017D.
Typically all the codes and lights clear when you shut it off only to pop up again at some point.
Could my instrument cluster be on it's way out? CANBUS problem?
I'm frustrated and about to flip this thing into a bar ditch and set it on fire.
