Sorry yeah that’s what I was referring to. Only because if I decide to run a winch, I want a little lift to compensate for the extra added weight
Thanks
Ok i'll have to say that it could be done, I have a K5 Blazer that I needed the rear of the body higher then the front. I had to make shims for all the body mounts between the front one and the rear one at different thicknesses so that the body was properly supported. It was alot of work and from looking at it you can't tell it's like that.
Yes, what I meant to say is IF he were to run them all around (front and back), it would be fine. But of course running them just in the front is not going to work.
