B bart5495 New Member Joined Nov 23, 2022 Messages 1 Location 98020 Nov 23, 2022 #1 Stock 09 Rubicon unlimited. Would 285/70r/17 work okay Reactions: mrjp
Dirty Dog JK Addict Supporting Member Lifetime Supporting Member Joined Sep 18, 2022 Messages 1,429 Location Pueblo West, CO Nov 23, 2022 #2 Almost certainly. You might have a bit of rubbing it you flex it up without any lift, though. Reactions: mrjp, Speartip and BigAL07
coolarmybrat New Member Joined Jun 26, 2022 Messages 3 Location Norwalk, Ca Nov 24, 2022 #3 That is perfectly fine but as previously mentioned, you might get some rubbing. If you have stock rims, you will need at least a 1.25" spacer to avoid the rubbing and at least a 2" lift to avoid hitting your fender (while flexing). Reactions: mrjp
