I have a hard top. I just noticed the water yesterday it was about 2 1/2 inches worth of water under the little cargo tub, where the jack is stored. We have had some rain in Texas, but this has never happened before, (Has always leaked at the front doors, even after 6 visits to the Jeep dealer) I have been taking it to the hand held car wash a lot. Carpet and mat in back were dry. Jack is completely rusted. It really surprised me.Does this happen when it's raining? If so, are you running a hard top or a soft top?
Thank you
The 12 I bought this summer had the same issue. I replaced it with a bottle jack.I bought a used 2013 JKU this summer and just opened that little compartment to check the Jack to go on sand (permit requires a working Jack). I found a completely rusted in place Jack and about an inch of rusty water in there. Had to sledge hammer the Jack out and put a new small hole in the plug like Troy66/68 suggested. Regular check in on the Jack compartment is probably a good idea for all
I was thinking the same thingNot sure how floor pan drain plugs were allowing water into the jack storage, which is right in front of the tailgate.
Hey Mac- Thanks for your reply. I also got the Morryde tailgate hinge. The thing is awesome! Much more sturdy and secure than OEM hinge. I will check the cabin pressure flap. The drain on the bottom of the Jack storage area was clogged so I hope that helped.The 12 I bought this summer had the same issue. I replaced it with a bottle jack.
I think all my water was coming from a completely rotted out cabin air pressure flap on the tailgate. Removing that and replacing it with a siliconed on delete plate while installing Morryde tailgate reinforcement seems to have stopped the dust and water.
Now I just need to get the freedom top to stop leaking on the radio...
-Mac
I have a 2016 Jeep Wrangler 4 door and found several inches of water in the jack storage area. Has anyone had this happen? And if so have you located how the water is getting in?
