Unforgiving new suspension
Thanks man. I will have them adjust that when I go in for the 500 mile check up. I also determined last night the steering does not want to return to center even in a turn. I took my hands of the wheel for a second while in a turn and it just stayed in the turn. Did not naturally want to return to straight as per normal. Something must be too tight
You want it to feel better? First, if you don't have at least adjustable lower control arms, pick them up. Then have them installed and set your caster at 6 degrees, toe-in at 1/16th inch. You'll have the feel you're looking for.
Thanks
