I have a 2012 Sport and the traction control will not turn off when I press the button it will only go off in 4Low. The hill decent will not come on either when I press the button. Does anyone have a solution for this issue?
Traction control automatically turns off in 4 Low.
It should turn off in 4 Hi if you press button . Mine turns off right away when I press the button .
Possibly contacts in button worn out .
Hill decent button not working either ? That's something your going to want to research .
As there is a specific way it should be used or Possibly worn out connectors there as well.
If both on same system in computer could possibly be trouble with main computer.
Which I wouldn't have an answer for. Could be simple as a reboot or much more
complicated.
I think they're on the same row of buttons, right? Maybe the harness begging the panel came loose or maybe the fuse popped for a random reason (it is a Jeep after all.
