Swaybar disconnect delete: How do I disable the light?
Jku_Rubigator
Nj
Ok so who knows how to jump it to get the light off?
Download the J-Scan app and purchase one of these:
https://www.amazon.com/gp/product/B06XGB4873/?tag=jkforum-20
Once that's done, open J-Scan on your phone, pair it to that OBDII port reader, and then register the J-Scan app to your VIN (it costs less than $20).
Once you do that, you'll see an option to disable the factory sway bar system. Click on that, and you're good to go.
Next time you start up your vehicle, the light will be off and the system will be completely disabled.
You can thank me later ;)
Thanks but my only question is will that work with the superchips flashpak?
You can't disable the sway bar with the Superchips Flashpak, but you can run this app along side it and it won't cause any issue.
I know I’ve had it in for over a year now, i was just wondering about compatibility with the two. But thanks for the info
Oh, you won't have any issue with that. This J-Scan isn't doing anything other than changing values within your PCM (turning things off or on). It's not tuning it or anything.
I will thank you. Had enough of that light. Worth more than 20 dollars
I agree! That app is a lifesaver for so many things!
I disabled my TPMS with it as well, as that's one more shitty light I don't want to deal with.
The real dashboard questions are:
1. How do you dim the damn high-beam light.
2. How can I turn off all the lights for when I'm on lonely roads or in the bush.
Will it turn off the check engine light as well?
