I own a 2016 JK Willys with almost 130k miles - which I take pretty good care of (even cleaning the engine bay) and don't abuse it. So this just happened Tuesday morning (8/4/2026) on the drive to work: Approximately 5.5 miles to destination, I get one chime with a blinking yellow check engine light. I cut off the radio to listen for anything unusual - nothing - the warning goes off. I quickly notice the chime and light appear only when I step on the accelerator. Since the remainder of the ride to work is relatively flat, I nursed it the rest of the trip - getting lucky to catch all the green lights along the way, I suppose I triggered the warning light perhaps 8 - 10 times more (again triggered by acceleration). I detected a very slight chugging as I neared my destination. As I pulled into the lot and slowed to park, the engine quietly stalled. I restarted - it ran rough and stalled after 2 seconds or so. I had it flat-bedded to a shop near home. They diagnose a P0303 code to identify cylinder 3 and explain they checked the plug (was burnt) and wires. Then settled on a conclusion of cylinder compression suggesting repairs would be rather expensive - approaching the cost of engine replacement. They also explained they don't do that kind of work, and it would have to be outsourced - they would recommend a shop/someone along with a quote. Which is where I am now. Waiting for a price I expect will come in around $7,000 - $8,000. I'm no expert, so as a logical minded person, I suspect the problem might have something to do with fuel injection into cylinder 3 - hence the problem of no compression. I'm leaning toward having it flat-bedded to a nearly dealer for a second opinion/diagnostics test - maybe they'll come up with other options after they test it. I have a hard time believing my engine "suddenly - mysteriously and unexpectedly" has a problem this serious with absolutely no symptoms or indications leading up to it. Anyone else experience something like this? I'm open to possible explanations/suggestions/advice. Thanks in advance.
