Something seems like it's binding when making sharp turns
Albert
Colorado
I have an 07 jeep JK wrangler on a 3 1/2 inch Rubicon lift I have wheel lag I replaced the affected u joint on the front right but I still have wheel lag and I took apart the left-hand side and it was fine could it be another parts and if so what part would that be I’m drawing a blank
When you make a sharp turn in the Jeep it’s staggering as if something is bound and not wanting to go forward at the same speed
I'd like to help you but not familiar about what you mean by wheel lag.
When you make a sharp turn the vehicle make it seem like something is bound and not wanting to make the turn so the vehicle lurches forward las time I had this problem it was the right side U joint
It’s my 4 wheel drive shaft the u joint went out
You say it was the front driveshaft U joint? Is this the stock driveshaft? Do you do any offroading? If so your probably going to need a aftermarket driveshaft because of the 3.5" lift and the angle of the driveshaft.
