Security system issue. I think?
KellyJ
South Carolina
I've been having an intermittent problem when starting my 2012 JKU. I reset the security system, which seemed to help, but now its started again.
Anyone with a similar problem?
Is the little red dot lite up in the right corner of your cluster when it happens? If so could be your key FOB battery is weak.
Reactions: Danarch
It does. Comes on for three to five seconds then goes off. I replaced the battery in the FOB which didn't change anything. I also tried the spare key with the same results.
Not sure if this will do anything for that or not but it doesn't cost anything.
Have you checked the small wire terminal on the starter to see if it's tight and clean. I remember now a couple others have had a issue with the terminal being loose and not making good contact.
