So I previously posted of a check engine light and code. It is P0305 (misfire on cylinder 5). I figure if I swap the plugs I should be good? I look at a video showing what I need to do to get to the plugs and am thinking while there I should just swap the coil packs while I am there. I was also wondering if I should change the fuel injectors as well? 155k miles
Thoughts?
also the misfire is not regular but has happened. Usually in the morning at start up and it runs a bit rough for a couple minutes but cleans up once driving.
Thoughts?
