A bearing noise that occurs when releasing the clutch pedal to engage the clutch while in neutral, but goes away when the pedal is depressed is caused by a bad transmission input shaft bearing.
That being said, it sounds like your input shaft bearing is toast. Don't drive on that, get it fixed ASAP.
