J Jshearin18 New Member Joined Mar 3, 2021 Messages 6 Location Oxford Apr 13, 2021 #1 What is an estimate to get a input shaft bearing replaced? I have a ticking noise under the car that goes away when I push down on the clutch thanks
Hooperdog JK Enthusiast Joined Aug 31, 2020 Messages 123 Location Northern Michigan Apr 13, 2021 #2 isn't that the throw out bearing? Reactions: mrjp
OP J Jshearin18 New Member Joined Mar 3, 2021 Messages 6 Location Oxford Apr 13, 2021 #3 Hooperdog said: isn't that the throw out bearing? Click to expand... It might be I’m not 100% sure. It occasionally slips out of 1st gear as well
OP J Jshearin18 New Member Joined Mar 3, 2021 Messages 6 Location Oxford Apr 13, 2021 #4 Jshearin18 said: It might be I’m not 100% sure. It occasionally slips out of 1st gear as well Click to expand... I thought the throw out bearing would make noise when clutch is pushed in?
Hooperdog JK Enthusiast Joined Aug 31, 2020 Messages 123 Location Northern Michigan Apr 17, 2021 #5 Jshearin18 said: I thought the throw out bearing would make noise when clutch is pushed in? Click to expand... my old TJ throw out bearing rattled until you pushed in on the clutch. put pressure on it. Reactions: mrjp
