How to Find and Fix Water Leaks
Vman
Pacific NW
A common issue with our JK's is water leaking into the interior.
The problems aren't always obvious, such as when water is leaking into rear fender holes and winding up on your front carpet/flooring.
The information in the link/attachment will help you isolate and fix these leaks and has been helpful to me on two different occasions.
Also included at the end of the document are P/N's and descriptions of the seals/foam you will need to replace as our vehicles age.
  • Jeep_Diagnosis_and_Repair_Manual_for_Leaks(2).pdf
Reactions: JBell
