Hi guy I am not sure if this has to be a written procedure or if videos are allowed but a few years ago I made a video on changing the transmission lines because they were leaking. It is very easy to do if you know the little tricks. This video covers replacing only the rubber portion of the lines but I did that by removing the entire assembly to make it easier. So if you decide to replace the entire cooler line assembly this will still apply. If links to videos are not allowed you can delete it.
