Driveshaft clicking only when turning in 4wd.
Fistlaw
Texas
Title says it.
Been at the shop for a few days getting axle seals replaced.
Back together and there’s a click from the front drive shaft only when in 4wd and turning.
Thoughts or ideas on how to specifically diagnose/rule things out?
TIA
I concur with the driveshaft u-joint. Especially if your ride has a lift, but less than 2.5 or 3", which does not necessarily require a driveshaft change due to the geometry. Although the angle is not severe enough to require a longer driveshaft, the angle does add a little more strain to the u-joints than the stock geometry.
(Hope that makes some sense)
