C2206:
Step 1. Verify the DTC is active
Turn the ignition on, with the scan tool select ''Miscellaneous Functions'' and restore vehicle configuration. With the scan tool, record and erase the DTCs. Cycle the ignition switch off then on. With the scan tool read the DTCs.
Is the DTC active at this time?
Yes, go to step 2.
No, Perform the
ABS Verification Test.
Step 2. Initialize the ABS Module
Cycle the ignition switch off then on. With the scan tool, under ''Miscellaneous Functions'' run the ABS Initialization routine. With the scan tool, erase DTCs. With the scan tool, read the DTCs.
Does the DTC remain active?
Yes, replace the Anti-lock Brake System (ABS) Module. Perform the
No, test complete, the condition or conditions that originally set this DTC are not present at this time.
C123A:
If the calculated checksum does not match stored checksum.
Related
Possible causes C123A code:
- Antilock Brake System (ABS) Module.
Diagnose C123A-ESP system sensors calibration
Step 1. Initialize Antilock Brake System (ABS) Module
Initialize ECU refer to ABS verification test.
Does this DTC reset ?
Yes, replace the Antilock Brake System (ABS) Module. Perform the
No, test complete for the DTC C123A-ESP System sensors calibration.
