Any trick to removing 2015 JK Stock Axle
Danarch
JK Addict
Orangevale, CA
I’ve the four nuts off, dust cover is loose, diff cover is off. Seems like with a little pressure on the end of the shaft the axle should pop loose / slide out but it is budging and don’t want to ruin anything in the diff. Any thoughts? Doesn’t seem like there is a pin or anything that holds the axle in.
