ABS / Speed Sensor Wire
Speartip
JK Addict
Victoria BC , Canada
Next week repelacing rotors, pads / front hubs.
The sensor wire that is attached to Moog front
bearing is 37" long.
Does anyone know if that is the same length
as OEM ?
Reading reviews on the bearing , a few complained
wire is too short ?
I can order a couple Dorman wires that are for
sure correct length. Or possibly just reuse factory
wire. But I've read they break off easy when trying
to remove from bearing .
Just trying to get a handle on things . So when
doing the project I've got everything on hand .
Thanks
Reactions: BigAL07 and mrjp
For what it's worth, I've used Dorman without any issues. From a quality perspective, they're on par with OEM. Not spectacular, but gets the job done.
Ok thanks man .
Appreciate it .
Ordereded the Dorman wires.
When it's all done will start a different
tread with the wire lengths of the
Dorman
Moog/National
Factory
So if anyone else needs to know
It'll be on here. Kinda an obscure
question which don't think anybody
really had an answer for.
