2018 JK with standard transmission won’t turn over when key is turned
Scotter
Jonesboro, AR
My 2108 JK won’t turn over once the key is turned. It’s in neutral and clutch is pushed in. Battery is fine (not the issue). Have to try turning the key several times before it will start. Sometimes in just turn the key and wait and it will start.
so what’s my solution to this problem?
Thanks
Try putting the transfercase in 4 low and see if it will start. Some of the years will start when that is done.
Could have a loose connection at the starter or cables and clamps might need cleaned.
