2012 JKU check engine at high RPM, then turns off
BVlads51
Illinois
I have a ‘12 JKU that the CEL comes on when I get on the gas and the RPM hits above 5500. It beeps at me, the light flashes then turns off. Dealer already put new plugs and coils on just before I bought it. 108k miles. I ordered the Bluetooth code scanner to see if it shows any but it hasn’t arrived yet. Any ideas?
So I got P06DA code and now the CEL stays on. Spoke to the dealer and they think it’s either the Oil Pump or Oil Solenoid. I guess the oil pump has two different PSI based on what RPM the engine is running which would help explain the high RPM CEL that would go away. Now it’s on all the time so time to replace them both since they’re right next to each other and the same amount of labor to replace. Peace of mind.
It worked, not cheap but it worked
Update: my son was merging on the expressway last night and CEL came on again and then turned off again. Fml, back to the drawing board.
