I recently eliminated the Electronic Front Sway Bar on my 2010 Wrangler Unlimited Rubicon. I was wondering if there was a place to have it rebuilt? Seems doable just not interested in doin it myself.
If you are wanting to sell it, you may be able to sell it as is. There is an aftermarket manual system that people use. I am actually looking for one for the right price, but they are usually too high for me. I’ll just get the wife some quick links.
With the aftermarket manual setup the sway bar can be used on multiple Jeeps. I am not sure if the sway bar from 2007-2011 and 2012 to 2018 is interchangeable or not, if they are it can be used on any of those years.
What would the right price be for as is?
Price varies wildly in this area, quick search shows 175 to 600 with 600 being a working unit. I just reworked mine after a mishap, paid 300 for the actuator and 150 for a new wiring harness.
@Danarch The evo manual system isn’t too bad, around 120$.
An interest in purchasing my recently removed as is electronic sway bar?
Assuming it does not work I am guessing around $300 from a few I’ve seen. As @1o1Proof said $120 for the manual setup. For a total of $420 I’ll just get the disconnect links.
I am sure price varies by region.
It is prone to failure due to its design, not very weather tight, and as you can see expensive to fix. Otherwise, it is great (IMO)…on the road you have the stability of a connected bar, press a button from inside the cab and you are disconnected.Correct me if I'm wrong, but I've always heard the electronic swaybar is a piece of crap.
